Monitoring Foreman metrics
I am currently searching for the “right” way to monitor metrics of Foreman. However, I found two guides here:
So the first one is from 2019 but the last post of 2022 says:
What I found regarding that ruby-prometheus-client is slow response on metrics http endpoint · Issue #194 · prometheus/client_ruby · GitHub, which is still open (with the question if it is fixed or not but there is no definite answer)
The second one is from 2020 is the mentioned statsd way to do it.
Also this post looks like I should use statsd: How to organize Foreman monitoring? - #4 by Marek_Hulan
And this is basically the state of beginning 2023 - as far as I found discussions on that topic here in the community-forum. So just following that, I would guess I should use statsd.
But there is also the docs part:
https://docs.theforeman.org/nightly/Monitoring_Project/index-foreman-el.html
which is explaining the first way using the ruby-client of prometheus.
This documentation is also part of the documentation for RedHats Satellite 6.15 (Chapter 3. Setting up the metrics monitoring solution | Red Hat Product Documentation).
So that sounds that it might be fixed and now the prometheus client should be the way to go?
Is anyone monitoring foreman metrics with one of those solutions and maybe can confirm if that ruby-client-issue for prometheus is gone?
The prometheus client isn’t “fixed” as such, but we adjusted our usage of it to not run into the described problems too much.
So yes, the docs link is correct, please use it and report issues you find with it :slight_smile:
