Problems creating a repo for an ubuntu 20.04 host
I created a repo for ubuntu and get error “Cannot create repository version. Path is duplicated: dists/focal-updates/Release.” when syncing repo
populate repo with ubuntu packages
foreman-2.4.0-1.el7.noarch
foreman-proxy-2.4.0-1.el7.noarch
katello-4.0.0-1.el7.noarch
pulp-client-1.0-1.noarch
CentOS Linux release 7.9.2009
Hello All,
So, as the topic says Im having issues trying to create a repo for ubuntu 20.04 hosts (and later 18.04). I have functional CentOS 7 and EPEL repos.
I created the repo like so:
hammer repository create
–product “ubuntu-20.04”
–name “Focal-Updates”
–label “Focal-Updates”
–content-type “deb”
–gpg-key “DEB-GPG-KEY-Ubuntu”
–url “Index of /ubuntu”
–mirror-on-sync “no”
–deb-architectures “amd64”
–deb-components “main,restricted,universe,multiverse”
–deb-releases “focal-updates” \
I have had to remove the --gpg-key line in all my repo creations and do it in tha gui as hammer says its no longer a valid option as it was when creating repos on Foreman 2.31.and Katello 3.18
The repo looks like this:
When I sync the repo I get this:
Under Details it says:
Hopefully its an easy fix. Coming from Spacewalk, I have to admit Foreman/Katello has not been an easy transition for me. Im much more a sysadmin than a dev ops guy.
Steve
So, I removed all the components from the sync settings and changed the upstream url to Index of /ubuntu. Now when attempting to sync the repo , it will run for ~40 minutes and end like this
Im hoping someone can throw me a bone so I can get this working while I still have some hair left. Ive searched foreman, atix, ochrhino and redhat and found very little information and less help.
Steve
The initial bug (with the “Cannot create repository version.”) sounds a bit, but not exactly like Issue #8410: syncing deb-repos in pulp 3 fails with "The path for file... overlaps" - Debian Support - Pulp. I will need to check if the error message was changed between pulp versions. If it is the same bug, then that has been fixed in upstream pulp_deb and the fix will be included in the Katello 4.0.1 release.
The other bug you are seeing sounds like Issue #8692: Repository sync will fail if Debian components are defined on the remote - Debian Support - Pulp which was first reported yesterday, and I have not yet had a chance to look into.
I will post again once I know more.
I’ve followed the orcharino documentation and this Managing deb content in Foreman | Opensource.com, replacing Debian with Ubuntu where needed.
Tell me if you happen to hang on the Foreman IRC sometimes.
Adeleglise,
I saw that as well and it looks pretty simple , but it doesnt seem to want to be simple for me so far. What upstream url did you use ?? And no, I dont hang out there. Maybe I should start to sometime.
quba42,
I did actually find that link before posting. I also saw suggestions to remove all components under the sync settings which would sync all the components without explicitely listing them.
I was pretty excited. It looked like the sync was working. But, as stated, after around 40 mins or so , I got the message server disconnected. I tried a half dozen times or so with the same outcome. Ill be waiting eagerly to hear what you find.
Steve
Interesting (sort of), i i dont know enough about how all the components work to know if its related , but I updated to tfm-rubygem-foreman_discovery-17.0.0-1.fm2_4.el7.noarch. Now when I attempt to sync the repo with 0 or 1 components in the repo config , I get
“Cannot create repository version. Path is duplicated: dists/focal-updates/Release”.
All the above steps are attempts to config a working ubuntu repo on my lab instance running Foreman 2.4 and Katello 4.0.
I setup the same repo on my prod box running Foreman 2.3.1 and Katello 3.18 without issue except for having to create /var/lib/pulp/gpg-home manually.
Keep in mind that orcharhino is still using Pulp 2 for everything. By contrast the pulp3_deb integration for Katello is pretty new, and still needs a lot of testing and fixing. I hope this work will accelerate once Katello 4.0.1 and 3.18.4 are out. (These versions will contain a newer version of pulp_deb which will make it easier to backport bugfixes.) Right now we are finding a lot of bugs. :slightly_frowning_face:
I have tried without components “main,restricted,universe,multiverse”, it worked just fine
HI spk037 ,
where i can find gpg key .
Hi @spk037
Please have a look at Extracting GPG public key fingerprints from Release files in Managing Content. orcharhino docs also contain a list of used GPG public keys: GPG Keys for Ubuntu.
