Vertical Navigation
Changing Direction…
When the UXD team was tasked with identifying UI improvements for Foreman
one of the major improvements we could see was with the navigation.
As it stands now, Foreman uses the Horizontal Navigation Pattern
<http://www.patternfly.org/pattern-library/navigation/horizontal-navigation/#_>
found in PatternFly (see example below).
Our reasons for improving the current UI include better adaptability for
additional menu items and a friendlier responsive design layout.
As you can see from the below screen, the current menu does not react well
to screen constraints, dropping menu items onto a second line.
There are some notes worth addressing when contemplating moving towards a
vertical nav from a user experience perspective.
Firstly, though vertical nav supports a tertiary level, currently no nav
item is in need of it. It’s nice to know it’s available if desired.
Secondly, the current vertical nav is at its best when nav items are given
groupings and titles for those groups. The current horizontal nav
inconsistently groups items. Possible solutions could be to provide
groupings alternatively you could leave them as is. In the below mockup we
can see a secondary nav that has one untitled grouping and three titled
groupings (In Bold - Provisioning Setup, Templates, Compliance).
Additional information about the vertical nav and its functionality can be
found on the PatternFly blog
<https://blog.patternfly.org/vertical-navigation-finding-your-way/>.
An additional note: the idea of a vertical nav was based on our perspective
from a user experience team. I know that there will also be additional
considerations from a technical perspective. I’m looking forward to
everyone's feedback.
+1 I'm a fan of switching to a vertical navigation but I do have one question.
Is there a pattern for being able to collapse the vertical navigation? At times you don't need the navigation at all and it takes up roughly 1/6th of the screen (as opposed to roughtly 1/10th with the current horizontal navigation) so it would be nice if it could be minimized to the side until needed.
Walden
··· ----- Original Message ----- From: "Roxanne Hoover" To: "foreman-dev" Sent: Tuesday, November 22, 2016 8:24:06 AM Subject: [foreman-dev] Vertical Navigation
Changing Direction…
https://blog.patternfly.org/vertical-navigation-finding-your-way/.
everyone’s feedback.
You received this message because you are subscribed to the Google Groups “foreman-dev” group.
To unsubscribe from this group and stop receiving emails from it, send an email to foreman-dev+unsubscribe@googlegroups.com.
> question.
> needed.
is there an assumption we should move to full width with this change?
thanks!
Ohad
··· On Tue, Nov 22, 2016 at 3:57 PM, Walden Raines wrote:
Walden
To: “foreman-dev” foreman-dev@googlegroups.com
Changing Direction…
+1
– bk
··· On 11/22/2016 09:05 AM, Ohad Levy wrote: > > > On Tue, Nov 22, 2016 at 3:57 PM, Walden Raines > wrote: > > +1 I'm a fan of switching to a vertical navigation but I do have one > question. > > Is there a pattern for being able to collapse the vertical > navigation? At times you don't need the navigation at all and it > takes up roughly 1/6th of the screen (as opposed to roughtly 1/10th > with the current horizontal navigation) so it would be nice if it > could be minimized to the side until needed. > > > is there an assumption we should move to full width with this change? > > thanks! > Ohad
I personally was making that assumption based on the screen in the patternfly vertical navigation documentation [1] and I support using a container that is very close to full width (i.e. you'll still want some padding so you can easily tell that things aren't appearing off screen).
Cheers,
Walden
[1] http://www.patternfly.org/pattern-library/navigation/vertical-navigation
··· ----- Original Message ----- From: "Ohad Levy" To: "Foreman" Sent: Tuesday, November 22, 2016 9:05:42 AM Subject: Re: [foreman-dev] Vertical Navigation
On Tue, Nov 22, 2016 at 3:57 PM, Walden Raines walden@redhat.com wrote:
+1 I’m a fan of switching to a vertical navigation but I do have one
question.
times you don’t need the navigation at all and it takes up roughly 1/6th of
needed.
thanks!
Ohad
Walden
Changing Direction…
Walden, Yes! The Patternfly vertical nav does have a collapsible feature.
If you read the design notes, secondary and tertiary levels can be "pinned"
to the left. There is also a version I have seen which is icon only however
I'm not seeing the documentation at the moment.
I also agree with your statement on full width. Reducing the margin/padding
will make better use of the space for responsive purposes.
··· On Wednesday, November 23, 2016 at 10:55:51 AM UTC-5, Walden Raines wrote: > > > is there an assumption we should move to full width with this change? > > I personally was making that assumption based on the screen in the > patternfly vertical navigation documentation [1] and I support using a > container that is very close to full width (i.e. you'll still want some > padding so you can easily tell that things aren't appearing off screen). > > Cheers, > Walden > > [1] > http://www.patternfly.org/pattern-library/navigation/vertical-navigation > > > ----- Original Message ----- > From: "Ohad Levy" <ohad...@gmail.com > > To: "Foreman" <forem...@googlegroups.com > > Sent: Tuesday, November 22, 2016 9:05:42 AM > Subject: Re: [foreman-dev] Vertical Navigation > > On Tue, Nov 22, 2016 at 3:57 PM, Walden Raines > wrote: > > > +1 I'm a fan of switching to a vertical navigation but I do have one > > question. > > > > Is there a pattern for being able to collapse the vertical navigation? > At > > times you don't need the navigation at all and it takes up roughly 1/6th > of > > the screen (as opposed to roughtly 1/10th with the current horizontal > > navigation) so it would be nice if it could be minimized to the side > until > > needed. > > > > is there an assumption we should move to full width with this change? > > thanks! > Ohad > > > > > Thanks, > > Walden > > > > ----- Original Message ----- > > From: "Roxanne Hoover" <roho...@redhat.com > > > To: "foreman-dev" <forem...@googlegroups.com > > > Sent: Tuesday, November 22, 2016 8:24:06 AM > > Subject: [foreman-dev] Vertical Navigation > > > > > > > > Changing Direction... > > > > When the UXD team was tasked with identifying UI improvements for > Foreman > > one of the major improvements we could see was with the navigation. > > > > As it stands now, Foreman uses the Horizontal Navigation Pattern > > > horizontal-navigation/#_> > > found in PatternFly (see example below). > > > > Our reasons for improving the current UI include better adaptability for > > additional menu items and a friendlier responsive design layout. > > > > As you can see from the below screen, the current menu does not react > well > > to screen constraints, dropping menu items onto a second line. > > > > > > There are some notes worth addressing when contemplating moving towards > a > > vertical nav from a user experience perspective. > > > > Firstly, though vertical nav supports a tertiary level, currently no nav > > item is in need of it. It’s nice to know it’s available if desired. > > > > Secondly, the current vertical nav is at its best when nav items are > given > > groupings and titles for those groups. The current horizontal nav > > inconsistently groups items. Possible solutions could be to provide > > groupings alternatively you could leave them as is. In the below mockup > we > > can see a secondary nav that has one untitled grouping and three titled > > groupings (In Bold - Provisioning Setup, Templates, Compliance). > > > > > > > > Additional information about the vertical nav and its functionality can > be > > found on the PatternFly blog > > . > > > > An additional note: the idea of a vertical nav was based on our > perspective > > from a user experience team. I know that there will also be additional > > considerations from a technical perspective. I’m looking forward to > > everyone's feedback. > > > > -- > > You received this message because you are subscribed to the Google > Groups > > "foreman-dev" group. > > To unsubscribe from this group and stop receiving emails from it, send > an > > email to foreman-dev...@googlegroups.com . > > For more options, visit https://groups.google.com/d/optout. > > > > -- > > You received this message because you are subscribed to the Google > Groups > > "foreman-dev" group. > > To unsubscribe from this group and stop receiving emails from it, send > an > > email to foreman-dev...@googlegroups.com . > > For more options, visit https://groups.google.com/d/optout. > > > > -- > You received this message because you are subscribed to the Google Groups > "foreman-dev" group. > To unsubscribe from this group and stop receiving emails from it, send an > email to foreman-dev...@googlegroups.com . > For more options, visit https://groups.google.com/d/optout. >
After some reviews with the visual team. I've made some changes to the
color scheme. The Foreman masthead will remains the same, but I've updated
the remaining colors to the default patternfly colorscheme. I believe this
will be better for color-blindness and overall longterm visual engagement.
I met with a user recently who was color-blind - which prompted me to make
some updates. Any feedback welcomed!
··· On Monday, November 28, 2016 at 10:14:14 AM UTC-5, Roxanne Hoover wrote: > > Walden, Yes! The Patternfly vertical nav does have a collapsible feature. > If you read the design notes, secondary and tertiary levels can be "pinned" > to the left. There is also a version I have seen which is icon only however > I'm not seeing the documentation at the moment. > > I also agree with your statement on full width. Reducing the > margin/padding will make better use of the space for responsive purposes. > > On Wednesday, November 23, 2016 at 10:55:51 AM UTC-5, Walden Raines wrote: >> >> > is there an assumption we should move to full width with this change? >> >> I personally was making that assumption based on the screen in the >> patternfly vertical navigation documentation [1] and I support using a >> container that is very close to full width (i.e. you'll still want some >> padding so you can easily tell that things aren't appearing off screen). >> >> Cheers, >> Walden >> >> [1] >> http://www.patternfly.org/pattern-library/navigation/vertical-navigation >> >> >> ----- Original Message ----- >> From: "Ohad Levy" >> To: "Foreman" >> Sent: Tuesday, November 22, 2016 9:05:42 AM >> Subject: Re: [foreman-dev] Vertical Navigation >> >> On Tue, Nov 22, 2016 at 3:57 PM, Walden Raines >> wrote: >> >> > +1 I'm a fan of switching to a vertical navigation but I do have one >> > question. >> > >> > Is there a pattern for being able to collapse the vertical navigation? >> At >> > times you don't need the navigation at all and it takes up roughly >> 1/6th of >> > the screen (as opposed to roughtly 1/10th with the current horizontal >> > navigation) so it would be nice if it could be minimized to the side >> until >> > needed. >> > >> >> is there an assumption we should move to full width with this change? >> >> thanks! >> Ohad >> >> > >> > Thanks, >> > Walden >> > >> > ----- Original Message ----- >> > From: "Roxanne Hoover" >> > To: "foreman-dev" >> > Sent: Tuesday, November 22, 2016 8:24:06 AM >> > Subject: [foreman-dev] Vertical Navigation >> > >> > >> > >> > Changing Direction... >> > >> > When the UXD team was tasked with identifying UI improvements for >> Foreman >> > one of the major improvements we could see was with the navigation. >> > >> > As it stands now, Foreman uses the Horizontal Navigation Pattern >> > > > horizontal-navigation/#_> >> > found in PatternFly (see example below). >> > >> > Our reasons for improving the current UI include better adaptability >> for >> > additional menu items and a friendlier responsive design layout. >> > >> > As you can see from the below screen, the current menu does not react >> well >> > to screen constraints, dropping menu items onto a second line. >> > >> > >> > There are some notes worth addressing when contemplating moving towards >> a >> > vertical nav from a user experience perspective. >> > >> > Firstly, though vertical nav supports a tertiary level, currently no >> nav >> > item is in need of it. It’s nice to know it’s available if desired. >> > >> > Secondly, the current vertical nav is at its best when nav items are >> given >> > groupings and titles for those groups. The current horizontal nav >> > inconsistently groups items. Possible solutions could be to provide >> > groupings alternatively you could leave them as is. In the below mockup >> we >> > can see a secondary nav that has one untitled grouping and three titled >> > groupings (In Bold - Provisioning Setup, Templates, Compliance). >> > >> > >> > >> > Additional information about the vertical nav and its functionality can >> be >> > found on the PatternFly blog >> > . >> > >> > An additional note: the idea of a vertical nav was based on our >> perspective >> > from a user experience team. I know that there will also be additional >> > considerations from a technical perspective. I’m looking forward to >> > everyone's feedback. >> > >> > -- >> > You received this message because you are subscribed to the Google >> Groups >> > "foreman-dev" group. >> > To unsubscribe from this group and stop receiving emails from it, send >> an >> > email to foreman-dev...@googlegroups.com. >> > For more options, visit https://groups.google.com/d/optout. >> > >> > -- >> > You received this message because you are subscribed to the Google >> Groups >> > "foreman-dev" group. >> > To unsubscribe from this group and stop receiving emails from it, send >> an >> > email to foreman-dev...@googlegroups.com. >> > For more options, visit https://groups.google.com/d/optout. >> > >> >> -- >> You received this message because you are subscribed to the Google Groups >> "foreman-dev" group. >> To unsubscribe from this group and stop receiving emails from it, send an >> email to foreman-dev...@googlegroups.com. >> For more options, visit https://groups.google.com/d/optout. >> >
I see you've folded the org switcher as the main top level entry, is there
another place we could put this context switcher instead ?
thanks!
Ohad
If you read the design notes, secondary and tertiary levels can be “pinned”
I’m not seeing the documentation at the moment.
container that is very close to full width (i.e. you’ll still want some
padding so you can easily tell that things aren’t appearing off screen).
Cheers,
Walden
l-navigation
To: “Foreman” forem...@googlegroups.com
question.
navigation? At
1/6th of
until
needed.
thanks!
Ohad
Walden
To: “foreman-dev” forem...@googlegroups.com
Changing Direction…
Foreman
for
well
towards a
nav
given
mockup we
titled
can be
perspective
Groups
an
Groups
an
an email to foreman-dev...@googlegroups.com.
Are you concerned about the priority or it being in the vertical nav?
I think there is room to have it located elsewhere. In patternfly the top
right hand mast head area allows for additional items.
··· On Monday, December 19, 2016 at 9:40:41 AM UTC-5, ohadlevy wrote: > > > > On Mon, Dec 19, 2016 at 4:38 PM, Roxanne Hoover > wrote: > >> After some reviews with the visual team. I've made some changes to the >> color scheme. The Foreman masthead will remains the same, but I've updated >> the remaining colors to the default patternfly colorscheme. I believe this >> will be better for color-blindness and overall longterm visual engagement. >> I met with a user recently who was color-blind - which prompted me to make >> some updates. Any feedback welcomed! >> >> >> > I see you've folded the org switcher as the main top level entry, is there > another place we could put this context switcher instead ? > > thanks! > Ohad > >> >> On Monday, November 28, 2016 at 10:14:14 AM UTC-5, Roxanne Hoover wrote: >>> >>> Walden, Yes! The Patternfly vertical nav does have a collapsible >>> feature. If you read the design notes, secondary and tertiary levels can be >>> "pinned" to the left. There is also a version I have seen which is icon >>> only however I'm not seeing the documentation at the moment. >>> >>> I also agree with your statement on full width. Reducing the >>> margin/padding will make better use of the space for responsive purposes. >>> >>> On Wednesday, November 23, 2016 at 10:55:51 AM UTC-5, Walden Raines >>> wrote: >>>> >>>> > is there an assumption we should move to full width with this change? >>>> >>>> I personally was making that assumption based on the screen in the >>>> patternfly vertical navigation documentation [1] and I support using a >>>> container that is very close to full width (i.e. you'll still want some >>>> padding so you can easily tell that things aren't appearing off screen). >>>> >>>> Cheers, >>>> Walden >>>> >>>> [1] >>>> http://www.patternfly.org/pattern-library/navigation/vertical-navigation >>>> >>>> >>>> ----- Original Message ----- >>>> From: "Ohad Levy" >>>> To: "Foreman" >>>> Sent: Tuesday, November 22, 2016 9:05:42 AM >>>> Subject: Re: [foreman-dev] Vertical Navigation >>>> >>>> On Tue, Nov 22, 2016 at 3:57 PM, Walden Raines >>>> wrote: >>>> >>>> > +1 I'm a fan of switching to a vertical navigation but I do have one >>>> > question. >>>> > >>>> > Is there a pattern for being able to collapse the vertical >>>> navigation? At >>>> > times you don't need the navigation at all and it takes up roughly >>>> 1/6th of >>>> > the screen (as opposed to roughtly 1/10th with the current horizontal >>>> > navigation) so it would be nice if it could be minimized to the side >>>> until >>>> > needed. >>>> > >>>> >>>> is there an assumption we should move to full width with this change? >>>> >>>> thanks! >>>> Ohad >>>> >>>> > >>>> > Thanks, >>>> > Walden >>>> > >>>> > ----- Original Message ----- >>>> > From: "Roxanne Hoover" >>>> > To: "foreman-dev" >>>> > Sent: Tuesday, November 22, 2016 8:24:06 AM >>>> > Subject: [foreman-dev] Vertical Navigation >>>> > >>>> > >>>> > >>>> > Changing Direction... >>>> > >>>> > When the UXD team was tasked with identifying UI improvements for >>>> Foreman >>>> > one of the major improvements we could see was with the navigation. >>>> > >>>> > As it stands now, Foreman uses the Horizontal Navigation Pattern >>>> > >>> > horizontal-navigation/#_> >>>> > found in PatternFly (see example below). >>>> > >>>> > Our reasons for improving the current UI include better adaptability >>>> for >>>> > additional menu items and a friendlier responsive design layout. >>>> > >>>> > As you can see from the below screen, the current menu does not react >>>> well >>>> > to screen constraints, dropping menu items onto a second line. >>>> > >>>> > >>>> > There are some notes worth addressing when contemplating moving >>>> towards a >>>> > vertical nav from a user experience perspective. >>>> > >>>> > Firstly, though vertical nav supports a tertiary level, currently no >>>> nav >>>> > item is in need of it. It’s nice to know it’s available if desired. >>>> > >>>> > Secondly, the current vertical nav is at its best when nav items are >>>> given >>>> > groupings and titles for those groups. The current horizontal nav >>>> > inconsistently groups items. Possible solutions could be to provide >>>> > groupings alternatively you could leave them as is. In the below >>>> mockup we >>>> > can see a secondary nav that has one untitled grouping and three >>>> titled >>>> > groupings (In Bold - Provisioning Setup, Templates, Compliance). >>>> > >>>> > >>>> > >>>> > Additional information about the vertical nav and its functionality >>>> can be >>>> > found on the PatternFly blog >>>> > . >>>> > >>>> > An additional note: the idea of a vertical nav was based on our >>>> perspective >>>> > from a user experience team. I know that there will also be >>>> additional >>>> > considerations from a technical perspective. I’m looking forward to >>>> > everyone's feedback. >>>> > >>>> > -- >>>> > You received this message because you are subscribed to the Google >>>> Groups >>>> > "foreman-dev" group. >>>> > To unsubscribe from this group and stop receiving emails from it, >>>> send an >>>> > email to foreman-dev...@googlegroups.com. >>>> > For more options, visit https://groups.google.com/d/optout. >>>> > >>>> > -- >>>> > You received this message because you are subscribed to the Google >>>> Groups >>>> > "foreman-dev" group. >>>> > To unsubscribe from this group and stop receiving emails from it, >>>> send an >>>> > email to foreman-dev...@googlegroups.com. >>>> > For more options, visit https://groups.google.com/d/optout. >>>> > >>>> >>>> -- >>>> You received this message because you are subscribed to the Google >>>> Groups "foreman-dev" group. >>>> To unsubscribe from this group and stop receiving emails from it, send >>>> an email to foreman-dev...@googlegroups.com. >>>> For more options, visit https://groups.google.com/d/optout. >>>> >>> -- >> You received this message because you are subscribed to the Google Groups >> "foreman-dev" group. >> To unsubscribe from this group and stop receiving emails from it, send an >> email to foreman-dev...@googlegroups.com . >> For more options, visit https://groups.google.com/d/optout. >> > >
I guess both, in a way, its a context you "log into" vs an action you take,
so i feel its similar to how you switch accounts in gmail for example.
On Mon, Dec 19, 2016 at 4:38 PM, Roxanne Hoover roho...@redhat.com >> wrote:
After some reviews with the visual team. I’ve made some changes to the
color scheme. The Foreman masthead will remains the same, but I’ve updated
I see you’ve folded the org switcher as the main top level entry, is
there another place we could put this context switcher instead ?
thanks!
Ohad
“pinned” to the left. There is also a version I have seen which is icon
only however I’m not seeing the documentation at the moment.
On Wednesday, November 23, 2016 at 10:55:51 AM UTC-5, Walden Raines >>>> wrote:
change?
Cheers,
Walden
l-navigation
On Tue, Nov 22, 2016 at 3:57 PM, Walden Raines wal...@redhat.com >>>>> wrote:
question.
navigation? At
1/6th of
horizontal
until
needed.
thanks!
Ohad
Walden
Changing Direction…
Foreman
for
react well
towards a
nav
given
mockup we
titled
can be
perspective
additional
Groups
send an
Groups
send an
I understand, it's certainly worth looking at an alternative position in
the masthead.
··· On Monday, December 19, 2016 at 9:49:39 AM UTC-5, ohadlevy wrote: > > > > On Mon, Dec 19, 2016 at 4:46 PM, Roxanne Hoover > wrote: > >> Are you concerned about the priority or it being in the vertical nav? >> > I guess both, in a way, its a context you "log into" vs an action you > take, so i feel its similar to how you switch accounts in gmail for example. > >> >> I think there is room to have it located elsewhere. In patternfly the top >> right hand mast head area allows for additional items. >> > >> >> On Monday, December 19, 2016 at 9:40:41 AM UTC-5, ohadlevy wrote: >> >>> >>> >>> On Mon, Dec 19, 2016 at 4:38 PM, Roxanne Hoover >>> wrote: >>> >>>> After some reviews with the visual team. I've made some changes to the >>>> color scheme. The Foreman masthead will remains the same, but I've updated >>>> the remaining colors to the default patternfly colorscheme. I believe this >>>> will be better for color-blindness and overall longterm visual engagement. >>>> I met with a user recently who was color-blind - which prompted me to make >>>> some updates. Any feedback welcomed! >>>> >>>> >>>> >>> I see you've folded the org switcher as the main top level entry, is >>> there another place we could put this context switcher instead ? >>> >>> thanks! >>> Ohad >>> >>>> >>>> On Monday, November 28, 2016 at 10:14:14 AM UTC-5, Roxanne Hoover wrote: >>>>> >>>>> Walden, Yes! The Patternfly vertical nav does have a collapsible >>>>> feature. If you read the design notes, secondary and tertiary levels can be >>>>> "pinned" to the left. There is also a version I have seen which is icon >>>>> only however I'm not seeing the documentation at the moment. >>>>> >>>>> I also agree with your statement on full width. Reducing the >>>>> margin/padding will make better use of the space for responsive purposes. >>>>> >>>>> On Wednesday, November 23, 2016 at 10:55:51 AM UTC-5, Walden Raines >>>>> wrote: >>>>>> >>>>>> > is there an assumption we should move to full width with this >>>>>> change? >>>>>> >>>>>> I personally was making that assumption based on the screen in the >>>>>> patternfly vertical navigation documentation [1] and I support using a >>>>>> container that is very close to full width (i.e. you'll still want some >>>>>> padding so you can easily tell that things aren't appearing off screen). >>>>>> >>>>>> Cheers, >>>>>> Walden >>>>>> >>>>>> [1] >>>>>> http://www.patternfly.org/pattern-library/navigation/vertical-navigation >>>>>> >>>>>> >>>>>> ----- Original Message ----- >>>>>> From: "Ohad Levy" >>>>>> To: "Foreman" >>>>>> Sent: Tuesday, November 22, 2016 9:05:42 AM >>>>>> Subject: Re: [foreman-dev] Vertical Navigation >>>>>> >>>>>> On Tue, Nov 22, 2016 at 3:57 PM, Walden Raines >>>>>> wrote: >>>>>> >>>>>> > +1 I'm a fan of switching to a vertical navigation but I do have >>>>>> one >>>>>> > question. >>>>>> > >>>>>> > Is there a pattern for being able to collapse the vertical >>>>>> navigation? At >>>>>> > times you don't need the navigation at all and it takes up roughly >>>>>> 1/6th of >>>>>> > the screen (as opposed to roughtly 1/10th with the current >>>>>> horizontal >>>>>> > navigation) so it would be nice if it could be minimized to the >>>>>> side until >>>>>> > needed. >>>>>> > >>>>>> >>>>>> is there an assumption we should move to full width with this change? >>>>>> >>>>>> thanks! >>>>>> Ohad >>>>>> >>>>>> > >>>>>> > Thanks, >>>>>> > Walden >>>>>> > >>>>>> > ----- Original Message ----- >>>>>> > From: "Roxanne Hoover" >>>>>> > To: "foreman-dev" >>>>>> > Sent: Tuesday, November 22, 2016 8:24:06 AM >>>>>> > Subject: [foreman-dev] Vertical Navigation >>>>>> > >>>>>> > >>>>>> > >>>>>> > Changing Direction... >>>>>> > >>>>>> > When the UXD team was tasked with identifying UI improvements for >>>>>> Foreman >>>>>> > one of the major improvements we could see was with the navigation. >>>>>> > >>>>>> > As it stands now, Foreman uses the Horizontal Navigation Pattern >>>>>> > >>>>> > horizontal-navigation/#_> >>>>>> > found in PatternFly (see example below). >>>>>> > >>>>>> > Our reasons for improving the current UI include better >>>>>> adaptability for >>>>>> > additional menu items and a friendlier responsive design layout. >>>>>> > >>>>>> > As you can see from the below screen, the current menu does not >>>>>> react well >>>>>> > to screen constraints, dropping menu items onto a second line. >>>>>> > >>>>>> > >>>>>> > There are some notes worth addressing when contemplating moving >>>>>> towards a >>>>>> > vertical nav from a user experience perspective. >>>>>> > >>>>>> > Firstly, though vertical nav supports a tertiary level, currently >>>>>> no nav >>>>>> > item is in need of it. It’s nice to know it’s available if desired. >>>>>> > >>>>>> > Secondly, the current vertical nav is at its best when nav items >>>>>> are given >>>>>> > groupings and titles for those groups. The current horizontal nav >>>>>> > inconsistently groups items. Possible solutions could be to provide >>>>>> > groupings alternatively you could leave them as is. In the below >>>>>> mockup we >>>>>> > can see a secondary nav that has one untitled grouping and three >>>>>> titled >>>>>> > groupings (In Bold - Provisioning Setup, Templates, Compliance). >>>>>> > >>>>>> > >>>>>> > >>>>>> > Additional information about the vertical nav and its functionality >>>>>> can be >>>>>> > found on the PatternFly blog >>>>>> > . >>>>>> >>>>>> > >>>>>> > An additional note: the idea of a vertical nav was based on our >>>>>> perspective >>>>>> > from a user experience team. I know that there will also be >>>>>> additional >>>>>> > considerations from a technical perspective. I’m looking forward to >>>>>> > everyone's feedback. >>>>>> > >>>>>> > -- >>>>>> > You received this message because you are subscribed to the Google >>>>>> Groups >>>>>> > "foreman-dev" group. >>>>>> > To unsubscribe from this group and stop receiving emails from it, >>>>>> send an >>>>>> > email to foreman-dev...@googlegroups.com. >>>>>> > For more options, visit https://groups.google.com/d/optout. >>>>>> > >>>>>> > -- >>>>>> > You received this message because you are subscribed to the Google >>>>>> Groups >>>>>> > "foreman-dev" group. >>>>>> > To unsubscribe from this group and stop receiving emails from it, >>>>>> send an >>>>>> > email to foreman-dev...@googlegroups.com. >>>>>> > For more options, visit https://groups.google.com/d/optout. >>>>>> > >>>>>> >>>>>> -- >>>>>> You received this message because you are subscribed to the Google >>>>>> Groups "foreman-dev" group. >>>>>> To unsubscribe from this group and stop receiving emails from it, >>>>>> send an email to foreman-dev...@googlegroups.com. >>>>>> For more options, visit https://groups.google.com/d/optout. >>>>>> >>>>> -- >>>> You received this message because you are subscribed to the Google >>>> Groups "foreman-dev" group. >>>> To unsubscribe from this group and stop receiving emails from it, send >>>> an email to foreman-dev...@googlegroups.com. >>>> For more options, visit https://groups.google.com/d/optout. >>>> >>> >>> -- >> You received this message because you are subscribed to the Google Groups >> "foreman-dev" group. >> To unsubscribe from this group and stop receiving emails from it, send an >> email to foreman-dev...@googlegroups.com . >> For more options, visit https://groups.google.com/d/optout. >> > >
In the screenie, I don't see the 'Administer' menu which today lives
visually distinct on the right hand side from the non-superuser items. In
this new nav, where would that live?
··· On Mon, Dec 19, 2016 at 9:51 AM, Roxanne Hoover wrote:
I understand, it’s certainly worth looking at an alternative position in
the masthead.
I guess both, in a way, its a context you “log into” vs an action you
top right hand mast head area allows for additional items.
On Mon, Dec 19, 2016 at 4:38 PM, Roxanne Hoover roho...@redhat.com >>>> wrote:
thanks!
Ohad
On Monday, November 28, 2016 at 10:14:14 AM UTC-5, Roxanne Hoover >>>>> wrote:
On Wednesday, November 23, 2016 at 10:55:51 AM UTC-5, Walden Raines >>>>>> wrote:
change?
Cheers,
Walden
l-navigation
On Tue, Nov 22, 2016 at 3:57 PM, Walden Raines wal...@redhat.com >>>>>>> wrote:
one
question.
navigation? At
1/6th of
horizontal
side until
needed.
change?
thanks!
Ohad
Walden
Changing Direction…
Foreman
navigation.
adaptability for
react well
towards a
no nav
desired.
are given
provide
mockup we
titled
perspective
additional
to
Groups
send an
Groups
send an
Eric D. Helms
Red Hat Engineering
Ph.D. Student - North Carolina State University
In other applications that have implemented the Patternfly vertical nav it
is in the top right position of the masthead.
··· On Monday, December 19, 2016 at 12:08:42 PM UTC-5, Eric Helms wrote: > > In the screenie, I don't see the 'Administer' menu which today lives > visually distinct on the right hand side from the non-superuser items. In > this new nav, where would that live? > > On Mon, Dec 19, 2016 at 9:51 AM, Roxanne Hoover > wrote: > >> I understand, it's certainly worth looking at an alternative position in >> the masthead. >> >> On Monday, December 19, 2016 at 9:49:39 AM UTC-5, ohadlevy wrote: >> >>> >>> >>> On Mon, Dec 19, 2016 at 4:46 PM, Roxanne Hoover >>> wrote: >>> >>>> Are you concerned about the priority or it being in the vertical nav? >>>> >>> I guess both, in a way, its a context you "log into" vs an action you >>> take, so i feel its similar to how you switch accounts in gmail for example. >>> >>>> >>>> I think there is room to have it located elsewhere. In patternfly the >>>> top right hand mast head area allows for additional items. >>>> >>> >>>> >>>> On Monday, December 19, 2016 at 9:40:41 AM UTC-5, ohadlevy wrote: >>>> >>>>> >>>>> >>>>> On Mon, Dec 19, 2016 at 4:38 PM, Roxanne Hoover >>>>> wrote: >>>>> >>>>>> After some reviews with the visual team. I've made some changes to >>>>>> the color scheme. The Foreman masthead will remains the same, but I've >>>>>> updated the remaining colors to the default patternfly colorscheme. I >>>>>> believe this will be better for color-blindness and overall longterm visual >>>>>> engagement. I met with a user recently who was color-blind - which prompted >>>>>> me to make some updates. Any feedback welcomed! >>>>>> >>>>>> >>>>>> >>>>> I see you've folded the org switcher as the main top level entry, is >>>>> there another place we could put this context switcher instead ? >>>>> >>>>> thanks! >>>>> Ohad >>>>> >>>>>> >>>>>> On Monday, November 28, 2016 at 10:14:14 AM UTC-5, Roxanne Hoover >>>>>> wrote: >>>>>>> >>>>>>> Walden, Yes! The Patternfly vertical nav does have a collapsible >>>>>>> feature. If you read the design notes, secondary and tertiary levels can be >>>>>>> "pinned" to the left. There is also a version I have seen which is icon >>>>>>> only however I'm not seeing the documentation at the moment. >>>>>>> >>>>>>> I also agree with your statement on full width. Reducing the >>>>>>> margin/padding will make better use of the space for responsive purposes. >>>>>>> >>>>>>> On Wednesday, November 23, 2016 at 10:55:51 AM UTC-5, Walden Raines >>>>>>> wrote: >>>>>>>> >>>>>>>> > is there an assumption we should move to full width with this >>>>>>>> change? >>>>>>>> >>>>>>>> I personally was making that assumption based on the screen in the >>>>>>>> patternfly vertical navigation documentation [1] and I support using a >>>>>>>> container that is very close to full width (i.e. you'll still want some >>>>>>>> padding so you can easily tell that things aren't appearing off screen). >>>>>>>> >>>>>>>> Cheers, >>>>>>>> Walden >>>>>>>> >>>>>>>> [1] >>>>>>>> http://www.patternfly.org/pattern-library/navigation/vertical-navigation >>>>>>>> >>>>>>>> >>>>>>>> ----- Original Message ----- >>>>>>>> From: "Ohad Levy" >>>>>>>> To: "Foreman" >>>>>>>> Sent: Tuesday, November 22, 2016 9:05:42 AM >>>>>>>> Subject: Re: [foreman-dev] Vertical Navigation >>>>>>>> >>>>>>>> On Tue, Nov 22, 2016 at 3:57 PM, Walden Raines >>>>>>>> wrote: >>>>>>>> >>>>>>>> > +1 I'm a fan of switching to a vertical navigation but I do have >>>>>>>> one >>>>>>>> > question. >>>>>>>> > >>>>>>>> > Is there a pattern for being able to collapse the vertical >>>>>>>> navigation? At >>>>>>>> > times you don't need the navigation at all and it takes up >>>>>>>> roughly 1/6th of >>>>>>>> > the screen (as opposed to roughtly 1/10th with the current >>>>>>>> horizontal >>>>>>>> > navigation) so it would be nice if it could be minimized to the >>>>>>>> side until >>>>>>>> > needed. >>>>>>>> > >>>>>>>> >>>>>>>> is there an assumption we should move to full width with this >>>>>>>> change? >>>>>>>> >>>>>>>> thanks! >>>>>>>> Ohad >>>>>>>> >>>>>>>> > >>>>>>>> > Thanks, >>>>>>>> > Walden >>>>>>>> > >>>>>>>> > ----- Original Message ----- >>>>>>>> > From: "Roxanne Hoover" >>>>>>>> > To: "foreman-dev" >>>>>>>> > Sent: Tuesday, November 22, 2016 8:24:06 AM >>>>>>>> > Subject: [foreman-dev] Vertical Navigation >>>>>>>> > >>>>>>>> > >>>>>>>> > >>>>>>>> > Changing Direction... >>>>>>>> > >>>>>>>> > When the UXD team was tasked with identifying UI improvements for >>>>>>>> Foreman >>>>>>>> > one of the major improvements we could see was with the >>>>>>>> navigation. >>>>>>>> > >>>>>>>> > As it stands now, Foreman uses the Horizontal Navigation Pattern >>>>>>>> > >>>>>>> > horizontal-navigation/#_> >>>>>>>> > found in PatternFly (see example below). >>>>>>>> > >>>>>>>> > Our reasons for improving the current UI include better >>>>>>>> adaptability for >>>>>>>> > additional menu items and a friendlier responsive design layout. >>>>>>>> > >>>>>>>> > As you can see from the below screen, the current menu does not >>>>>>>> react well >>>>>>>> > to screen constraints, dropping menu items onto a second line. >>>>>>>> > >>>>>>>> > >>>>>>>> > There are some notes worth addressing when contemplating moving >>>>>>>> towards a >>>>>>>> > vertical nav from a user experience perspective. >>>>>>>> > >>>>>>>> > Firstly, though vertical nav supports a tertiary level, currently >>>>>>>> no nav >>>>>>>> > item is in need of it. It’s nice to know it’s available if >>>>>>>> desired. >>>>>>>> > >>>>>>>> > Secondly, the current vertical nav is at its best when nav items >>>>>>>> are given >>>>>>>> > groupings and titles for those groups. The current horizontal nav >>>>>>>> > inconsistently groups items. Possible solutions could be to >>>>>>>> provide >>>>>>>> > groupings alternatively you could leave them as is. In the below >>>>>>>> mockup we >>>>>>>> > can see a secondary nav that has one untitled grouping and three >>>>>>>> titled >>>>>>>> > groupings (In Bold - Provisioning Setup, Templates, Compliance). >>>>>>>> > >>>>>>>> > >>>>>>>> > >>>>>>>> > Additional information about the vertical nav and its >>>>>>>> functionality can be >>>>>>>> > found on the PatternFly blog >>>>>>>> > < >>>>>>>> https://blog.patternfly.org/vertical-navigation-finding-your-way/>. >>>>>>>> >>>>>>>> > >>>>>>>> > An additional note: the idea of a vertical nav was based on our >>>>>>>> perspective >>>>>>>> > from a user experience team. I know that there will also be >>>>>>>> additional >>>>>>>> > considerations from a technical perspective. I’m looking forward >>>>>>>> to >>>>>>>> > everyone's feedback. >>>>>>>> > >>>>>>>> > -- >>>>>>>> > You received this message because you are subscribed to the >>>>>>>> Google Groups >>>>>>>> > "foreman-dev" group. >>>>>>>> > To unsubscribe from this group and stop receiving emails from it, >>>>>>>> send an >>>>>>>> > email to foreman-dev...@googlegroups.com. >>>>>>>> > For more options, visit https://groups.google.com/d/optout. >>>>>>>> > >>>>>>>> > -- >>>>>>>> > You received this message because you are subscribed to the >>>>>>>> Google Groups >>>>>>>> > "foreman-dev" group. >>>>>>>> > To unsubscribe from this group and stop receiving emails from it, >>>>>>>> send an >>>>>>>> > email to foreman-dev...@googlegroups.com. >>>>>>>> > For more options, visit https://groups.google.com/d/optout. >>>>>>>> > >>>>>>>> >>>>>>>> -- >>>>>>>> You received this message because you are subscribed to the Google >>>>>>>> Groups "foreman-dev" group. >>>>>>>> To unsubscribe from this group and stop receiving emails from it, >>>>>>>> send an email to foreman-dev...@googlegroups.com. >>>>>>>> For more options, visit https://groups.google.com/d/optout. >>>>>>>> >>>>>>> -- >>>>>> You received this message because you are subscribed to the Google >>>>>> Groups "foreman-dev" group. >>>>>> To unsubscribe from this group and stop receiving emails from it, >>>>>> send an email to foreman-dev...@googlegroups.com. >>>>>> For more options, visit https://groups.google.com/d/optout. >>>>>> >>>>> >>>>> -- >>>> You received this message because you are subscribed to the Google >>>> Groups "foreman-dev" group. >>>> To unsubscribe from this group and stop receiving emails from it, send >>>> an email to foreman-dev...@googlegroups.com. >>>> For more options, visit https://groups.google.com/d/optout. >>>> >>> >>> -- >> You received this message because you are subscribed to the Google Groups >> "foreman-dev" group. >> To unsubscribe from this group and stop receiving emails from it, send an >> email to foreman-dev...@googlegroups.com . >> For more options, visit https://groups.google.com/d/optout. >> > > > > -- > Eric D. Helms > Red Hat Engineering > Ph.D. Student - North Carolina State University >
